I bought ømëga from shadetree in August 99% rust free this is my second festiva festiver being my first now this is gonna be as perfect as a festiva can be in my eyes almost everything will modified
for drivetrain it will be a mk1 audi TT 1.8t awp engine mated to a capri xr2 g series with a 626 5th gear swap then engine will be mildly built with a k03s turbo aiming for 300 hp on a high boost tune and 180hp (stock) on low boost for suspension I want to do a Custom rear disk swap as I need 5x4.75 bolt pattern I'll use capri calipers and trans am rotors with custom hubs this will also be on the front as I have a set of 15x7 trans am snowflakes I am very determined to use
definitely will use Charlies suspension and I will go as low as I can I'll have to run 4°-5° of negative camber pull and roll the fenders im aiming to get the shipping hooks to be the lowest part of the car and 1" off the ground
Sent from my XT1585 using Tapatalk
definitely will use Charlies suspension and I will go as low as I can I'll have to run 4°-5° of negative camber pull and roll the fenders im aiming to get the shipping hooks to be the lowest part of the car and 1" off the ground Sent from my XT1585 using Tapatalk
