Past Grand Prairie I ran into an interesting problem. We ran into an incredible downpour and with my front tires being so worn and having to use so much throttle just to drive the car pulled all over in the wet. One tire would slip a little, then the other, then back to the other.... just little quarter second slips here and there switching sides made me take up the whole lane to do a normal speed so I had to slow down a fair bit. Hard rains also sent my fuel mileage into the tank: 26mpg.... From grande prairie we had a mad dash to westiva. We drove through that rain I just mentioned, went home for 1 hour to quickly do a wheel alignment and grab things we needed and get rid of things we didn't need. Turns out I had 1/4 inch of toe in.... So I gave myself 1/32 of toe. We got to Ian Cassleys (host for westiva) place at 9:30pm. We made 800km that day.
The next day was Westiva which was awesome. I locked my keys in my car and Julie had left her set in the car as well. Turns out 2 other attendees had keys that unlocked my car...
Leaving Westiva and going to my parents is where the big trouble started. It should have been a 3hr drive and it took us over 6hrs. There is a ring road around Calgary I was taking that has a decent hill, it was hot out and my temperature gauge was up but not out of the ordinary. Just as I was cresting the hill I lost most of my power and the temp gauge shot all the way up. I couldn't maintain speed and my temperature was too high and wasn't going down on the other side of the hill so I had to pull over on the freeway and let it cool off with the fan going. I couldn't see anything wrong so when I was back to 180f coolant I went to drive again. Made it about 2 miles, probably less and had to pull over. I still couldn't find anything wrong other than oil being sprayed on my engine and I couldn't find the source. I now thing the crankcase got over-pressurized and it blew out past seals and hose connections. so I removed my grille, retarded my timing and turned the cabin heat all the way up. I had a manual switch for my rad fan so it was always running. with the cabin heat on full and the windows open I could keep my temperature down to about 220f but I could only do 50mph on the flat, 40mph on hills. The speed limit on that freeway being 70mph and most people doing 75. On long hills my temperature would get too high and I had to pull over. I tried everything I could think of. I filled up with new gas, I stopped at a store to buy intake cleaner and grease and stuff and let the engine cool way off, but nothing helped. We had been driving like that for hours and I was cresting a hill at like 35mph with my instrument cluster temp gauge pegged at the top and I knew I had to pull over but i figured i would coast down the other side of the hill in 5th first to help the car cool off. Something happened going down that hill and my temperature gauge literally dropped like a rock and I had all my power back. I didn't shift out of 5th for like 45min because I had no idea if that had anything to do with it. We made it to my parents without it going bad again, it was really weird.
So then I removed my spark plugs and they were destroyed. All melted and blasted away from the detonation. cyl 1 and 4 were the worst. I borrowed my parents car and went to the nearby town but only had one choice for spark plugs, all the other stores had nothing for the festiva. we left the sick kids at my parents and I drove 1.5hrs home with the new plugs towing the trailer. I had the timing so far retarded that I had no power to get going in first gear. trying to leave a gas station parking lot that had a slight hill I stalled 4 times, even revving the car way up and slipping the clutch bad. Just no low down power. I asked a lot of questions and got a lot of help on the forum. I took my car to the shop where I work, bought colder spark plugs, looked in my cylinders with a boroscope but couldn't see anything with it. I tried to set my timing but my car would just die with the sti connection grounded so i couldn't. It didn't matter where i turned the distributor while the sti was grounded it would just die. I sprayed lots of cleaner down the intake manifold and the spark plug holes, cleaned the massive amounts of oil out of my intake tubing and vaf, tried to spray water in the intake while it was running to steam clean it.... I took all the negative camber out of the front and set the toe. Its incredible how much the toe has to change from -2deg to zero. I advanced my timing to where I could run midgrade gas (89 octane) with no knocking with the colder plugs. I removed my washer sprayer nozzle and aimed it at my radiator so if i got too hot again i could spray it at the rad and cool it more like that. never ended up using that. I changed my pcv routing again. I drilled out a pcv valve and vented both the pcv outlet and the other valve cover hole to my catch can which I vented to atmosphere. I ordered new tires to be shipped to Tabitha in thunder bay, my fronts were toast after only 12,000km (7500 miles). A week after we got home we were ready to go again to the east coast!
