So I purchased Ghost from Mark back in February and giving it lots of love. The car last dyno @220hp and Carlos tuned the Ms3. However it had a few issues such as a cracked manifold and the boost solenoid was not working.
Things that have been fixed/replaced
Replaced manifold with stainless ramhorn.
Replacing fuel rail with Obx rail and adjustable fpr.
Install pro sport Egt,electronic fuel pressure,electronic boost,coolant and electronic oil pressure gauges.
Running -8 supply and return lines
Made pick up tubes and baffle inside gas tank to reduce slosh.
Replaced front transmission solid mount with rubber mount
Replaced timing belt
Installed oil pump orings and redid oil pan gasket.
Welded bungs on valve cover for catch can
Installed 4x100 aspire swap
Re plumbed intercooler piping
Install poly control arm bushings
What is left to do
Mount catch can
Finish plumbing fuel system
Reinstall intake
Replace shifter bushings
Finish installing aspire ebrake cable
Make some type of air cleaner/screen for turbo
Find trans leak
Fix gauge cluster fuel gauge was not working.
Sand blast valve cover
Reinstall intake,make new throttle cable bracket.
Alignment
What is left to do
Mount catch can
Reinstall intake
Find trans leak
Alignment
