Finally got around to start working on the "Jalopnik Car" I picked up in New Jersey. This car has fallen from it's glory days; the passenger hub had a blown up wheel bearing and the transmission doesn't go into gear. Here's when I grabbed it:
Got it to my house a little while back. Took a side profile of it because I needed a comparison after I put the appropriate tires and my coilovers on it:
Now it's in the garage with no wheels on it (don't mind the garbage bag I just used the latch as a bag holder while I cleaned out some stuff):
Found a sweet old amp under the passenger seat, score!
One thing I need to do is swap over my 165-55-14s onto the Miata wheels. I only have like 100 miles on these tires before I got rid of my white car:
Put the front coilovers on:
Engine Pic:
List of things I wanna do:
1. Fix transmission. I might have to install the G-series I have.
2. Upgrade to the Auto Aspire brakes. (I blew up a caliper pressing the brakes while the caliper was off like an idiot)
3. Do something with the exhaust. The exhaust is really bad looking on the car.
4. Bypass the IAC because the car won't idle properly.
5. Move the MAF. The guy has it routed so poorly. Probably going to need a smaller battery.
6. Put my camber kit on the rear of the car.
Engine Pic:
