Alright, so I'm now at the end of my first week of Festiva ownership, and aside from it shutting off and not re-firing for 8 hours after driving through a "puddle" (small lake) at the end of my block it's been pretty good.
I plan on keeping this beautiful train wreck mostly stock as a fun little fuel efficient daily and back up car in case one of my other beaters goes down because I drive like an arse
I'll get some interior / under hood pics up probably this weekend, but for now, the good and bad
The Good
New tires (155/80R12) on all four corners (the donut in the pics is back in the trunk)
Rack and pinion and front suspension were replaced shortly before I got the car
Brand new battery
Brand new radiator
Heat blows strong
It's a factory A/C car
Has a cool 8-ball shifter knob
Factory Sunroof
Exhaust was replaced from the manifold back 3 years ago
"Custom" paint job (it looks sketchy but i kinda like it)
Came with a ton of awesome stickers pre-installed (and I've already started adding my own)
It only burns $10/week in gas compared to the $60/week my Suburban was drinking
5-speed is a blast
I only paid $400 for it
The Bad
The little B3 is a sewing machine (tick tick tick)
- I do have lifters (holy crap they're tiny!) a valve cover gasket, and full tune up kit ready to drop in
Valve cover leaks oil onto the exhaust manifold 9which smells AWESOME after about 2 miles of driving)
Leaks coolant slowly from somewhere (lots of loose and/or dry rotted lines I have to go through)
Temp gauge is non-op, I check the coolant every morning to be safe
Shifter is SUPER sloppy, and the clutch grabs like half an inch from the top of the throw
- I plan on fixing both of these at the same time somewhere in the near future with a new clutch and shifter bushings
Brakes are grinding, not looking forward to messing with drums again
No Radio, random aftermarket radio harness spliced into it
Drivers door doesn't like to open from the inside
Factory A/C doesn't work (no belt, pretty sure that isn't the only issue though)
Sunroof latch is broken, tried fixing it today with super glue and duct tape, no dice, getting a tube of JB Weld tomorrow and getting serious
3rd brake light held together with duct tape
Dome light doesn't work.
Ok, so she's got her problems, but is was 400 bucks!
