Went to the track tonight!!
    awesome work sir. congrats.
    got some info on what trans your are running? or a link for me to check out.
    "Its not fast, but its fast for a festiva."
      Here you go
      some research
      Discuss making performance enhancements to the OEM-spec engine in your Festiva or Aspire.
      The start
      The initial build thread
      Members Builds (questions about repair or how to do something belong in the proper forum)
      And the turbo thread (still in progress )
        I see you getting faster and faster without getting faster if that makes sense. The suspension think tank is really making me alter my purchases.
        1993 GL 5 speed
          This. Exactly what I was thinking. Nearly 200hp pulling well under 2k lbs and only a 14 second pass? You ain't kiddin' when you say you had no grip, I guess.
          Is it set up to drag, or just a street suspension having fun for a day?
            umm do you think MY festy still weighs under 2k lbs? Mine weighs about 2100lbs :lol: it was just simply wwaaayyyy too much tire spin
              Fine, but all the extra weight is over the grippers, yes? Maybe you need the "cat in heat" stance someone was talking about.
                Nah, a set of slicks should be all I'll need, Friday night the humidity was very high and they don't prep the track on a friday night unfortunately which obviously didn't help me at all
                  Yeah if you can cut a 1.9xx you will reap a whole new set of numbers to try and beat next time. I would first try and get some used slicks with half life left off CL. The honda sizes already mounted on wheels should be around on craigslist all day long. You may want a taller tire too, whatever can still fit, that may help the overall tranny ratio. On the other hand a smaller tire can help spinning issues because its easier to "catch up" when you modulate clutch and throttle. Since you are the one driving you would know what's happening to you realtime.
                  1993 GL 5 speed
                  • #24
                    I was browsing kijijI and may have found a decently priced set of used slicks, just gotta wait for a response
                    • #25
                      nice pass DK! that KL-ZE sure is sweet.
                      oh- i am sure that KL will gladly welcome a small 50 shot NOS drink
                      -Aspire brake swap COMPLETE!
                      • #26
                        Lol thanks, I think I'd rather have a bit of traction before nitrous though lol
                        • #27
                          Excuses....
                          Jk
                          -M3NTAL MARK! Woo!!
                          • #28
                            Just put 1 50lb barbell weight on the frame over each wheel. 200lbs should help with traction.
                            1990 White L-Plus 5-speed rust-machine
                            Scrapped
                            1991 Blue L 5-speed
                            daily driver, intermittent project
                            1993 rustless wonder
                            A shell, awaiting suspension, brakes, and B6T
                            • #29
                              Originally posted by M3NTAL View Post
                              Excuses...
                              Ya ya :p we'll wait and see what times you pull once you get yours to the track
                              • #30
                                Mines going to be a dyno queen probably lol
                                -M3NTAL MARK! Woo!!
