some BP have oil coolers...
  • some BP have oil coolers...
    Just saying - I did not know that. Looks like 93 and later escort GTs had stock oil coolers. Might be useful for some racing applications.
    Will try putting a cooler from a 93 e-gt to a 91 engine tomorrow.
    rusEfi - DIY ECU
    93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
    I believe all the FWD BP's from 90-94 had them, but the 95 and later ones and the miata ones did not.
    Facebook Me!
      Somehow I have two used BP engines (pre-93 crank style) without oil coolers and with short oil filter shaft.
      While we are on the subject of sweet stock stuff... Did not they have stock exhaust headers on some escorts? maybe 95?
      All I know we have found two rusted headers in junk yards - one next to a protege, another next to a escort. I do not think these were aftermarket accessories...
      rusEfi - DIY ECU
        There not, I've got a stock "header" also
        1991 blue L, 5 speed.
        1988 red L-plus-all stock.
          I was wondering what that thing under my oil filter was.. I dont have a socket big enough to get the nut off :/
          2008 Kia Rio- new beater
          1993 Festiva- Fiona, DD
          1997 Aspire- Babyspire, DD
          1994 Aspire - Project Kiazord
          1994 Aspire- Crustyspire, RIP
            My 92 escort gt motor had a oil cooler
              My 93 had one
              :cry_smile: RIP. 91 Ford festiva BP swap
              1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
                seems like the nut is about 26 mm, also the one in the junk yard was really loose - seems like it is mostly held by the oil filter pushing it against the engine
                rusEfi - DIY ECU
                  zoom zoom leave it on, your heater core lines run through it, unless you are going aftermarket larger oil cooler.
                  Facebook Me!
                    I was just gonna clean it all up..
                      I've run my bp for 40k miles without the oil cooler. No problems. I used a big adjustable wrench to get the nut off. Then I threaded the stock b3 one (short) into it. It helps clear the intermediate shaft for the g series transmission.
                      -Greg
                      Redneck Engineer
                      FOTY - '09
                        ive been running both my b6t and my BP with the oil cooler since day 1 with a G series with no clearance issues. both the cable and the hydro trans
                          Another tip: if you have a Ford non-MBSP BP, and can't find a DOHC Protege to source one the B8ME has an MBSP that bolts on to the EGT motor. It doesn't clear ARP mainstuds though.
