Drag Racing Tonight!!!
  • Drag Racing Tonight!!!
    I'm taking the Festiva down to the local Drag Strip tonight. I just want to see how slow the B3 will go... I had a friend that drives a metro that was supposed to meet me out there because he thinks he can beat me but he flaked out. I'll post some Stock B3 1/8 mile times tomorrow when I have time. rasm
    Ran an 11.86 1/8th mile.
    I did launch really well on one pass and beat a new Challenger off the line until I realized it was mostly just my reaction time lol...
      I also met an old man out there driving an 80's model Ford Escort called Underdog that was very interested in my car. I talked to him for a bit and found out he does bracket racing with it for the past 20 years and wins quite a bit.
        Sounds like a fun time. That's a pretty solid run for a 23 year old car with 64hp.
          Power to Weight Ratio - it kicks ass every time!
          Most people don't drive what they want at all, and never will
            What's your current setup?
              Just a Bone Stock B3. Stock Tires. I might have shaved about 40-50 Pounds of extra weight but I'm about 220lbs so I could stand to shave about 40 pounds off of me too lol. I just ordered a Innovative Motorsports Wideband 02 Sensor which should be here tomorrow. It might be a little while before it goes in because of the lack of funds. I'm probably going to do a 1.75" full exhaust(Down pipe and back) done and then get the bung welded into that at the same time. I have a Borla Muffler waiting to get welded on as well.
              I also have a cheap Tach that is about to go in. That night I went to go leave I realized that my Cluster had come unplugged and it was too late to fix it so I was racing with no Tach or Speedo and had no clue how much fuel I had or if the car was overheating lol
                It seams like there isn't a whole lot of power on the bottom end. The odometer says 147k so I'm assuming that is what is on the engine. When I first got it the valve train ticked really bad but after an oil change and then adding a quart of ATF and letting it idle for about 10 minutes at a time for about 2-3 months while I worked on getting it road ready and then another oil change it has basically gone away... until it the car hits operating temp and then it taps more than I would like it to. Not sure if that will eventually run itself out being that I have only ran about $25 worth of gas through it so far. Anyone else have this problem?
                  I uses to but I use stp with zddp and the tick quit for good.
                  I no longer have the b3 but I still use the stp with ever oil change in my b6d.
                  I've also used atf to clean my engine when I first got it and it dose pretty good. I like seafoam as well.
                    I plan to eventually pull the head and try to do some amateur port and polishing so if it doesn't stop ticking by then I guess I will find out what is going on.... I want to watch a few more videos and pick up the correct tools before I tackle that job though. This is all a learning phase for me.
                      I have a thread in here somewhere about how I ported mine....
                        I'll have to look it up when it comes to that point. How much of a difference did you notice after? I also want to check the timing to see if I can get a little more out of it, I don't drive it that much so putting 93 octane in it isn't really that big of a deal for me if I can advance the timing a few degrees and get a little more power out of it.
                        I have a Wet Nitrous System that I'm going to hook up once I get the exhaust done so I will be running 93 octane anyway to make sure I don't lean out.
                          Top end power changed significantly with the port job.
                          If you run 93 oct, you can set base timing to +10 right out of the gate and tune from there.
                            Do you know what the stock timing is set at? When you set the timing to +10 do you set that at idle or revving? I watched a video on Youtube that showed that the timing changed when revved but I have no clue if that works the same on our cars.
                              FestYboy I found the Thread you were talking about, I also found another one of your threads talking about Matt Dickmeyer and found some other Photo's as well.
