I am building a full on 1/8 & ¼ mile drag racer, never to be driven on the street. It is to be only towed everywhere race car.
I am looking for ideas and suggestions to make the car very competitive, so if anything comes to mind, let me know.
NO turbo – just the EFI.
When it comes to suspension, the car only has to get up to the starting line, go a 1/4-mile, do one 180-degree turn off the track, and go back to the pits/start line. There is no need of any type of road racing suspension – I'm just going in a straight line!
The car, RED, is a 1992 Festiva that has been gutted – and I mean gutted.
It will be using a 1994 Ford Escort GT BP engine with exintake cam swap to begin with.
Currently it has a 1988 Capri xr2 cable “G” series transmission in it with 3.8 (?) gears.
Front suspension/brakes/axles are all from the same xr2 as the transmission.
Front hubs have 114 diameter 4-bolts and the rims currently on the car are 14 x 6 from the xr2
Front sway bar is a stock Festiva.
Rear axle is a stock Festiva.
Steering is stock Festiva.
PLANS:
The car will be further lighten with fiberglass doors, hood and rear hatch. If fiberglassing will take too long then the above components will be further lighten.
Glass windows (except windshield) will be replaced with Lexan
All window mechanism will be removed, as will internal door impact bars.
A single Kirkey alumium seat will be installed.
Tachometer, oil and water temp gauges installed
Fuel cell with 1.5 gallon capacity
External 40-osi electric fuel pump
Festiva radiator with plastic side pieces
Aspire rear axle with 4 x 100 bolts
Aspire front hubs with 4 x 100 bolts and NO rotor or brake calipers NOTE: The original factory A/FX Plymouth's & Dodge's came with rear brakes ONLY, no front brakes. These cars operated at much higher speeds (125-140-mph) in the quarter mile and were much heavier than a Festiva and were always able to stop (sometimes with some excitement!!!)
Miata 6 spoke aluminum rims, front & rear
Small riding mower type battery, positioned either in front of the front bumper or in the passenger footwell.
Front bumper to be a rear Aspire bumper cover
Front & Rear steel bumper frames removed
Rear bumper to be stock Festiva bumper cover
No headlights, side lights, turn signals (F&R). Single brake light in rear.
Re-inforced lower front suspension points
Re-inforced front fender/frames (Hot Wheels making them)
All suspension to use delrin bearings
Festiva front swaybay
Front shock tower tie bar
Front lower suspension attachment points tie bar
Minimal wiring & use only 16/18 gauge wiring
Custom built Kia Sephia transmission with 4.39 gear
Manual brakes – brake booster to be removed
Those are the initial plans/ideas that I am working to.
So let's hear those ideas & input!!!
Doug
PLANS:
Doug
