map sensor
  • map sensor
    i was on the megasquirt homepage and it talks about a 3 bar and 4 bar map sensor. what is a map sensor on a car?
    Manifold Absolute Pressure. It is used in place of the airflow meter. It determines fuel requirements based on
    intake manifold pressure instead of the MAF to measure how much air the motor is getting. If you install a
    megasquirt or any other aftermarket EMS you will use this and can ditch your restrictive MAF. Basically
    your intake will look like a Honda intake with a filter, tube to the throttle body and nothing else in between.
    Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
    - Dennis Grant
    FarNorthRacing.com
      thanks for the info
