we have had some wonderful storms these past few days and now i have water on my passenger side footwall in the backseat worse than the front seat. its not coming in the window or the door because the seat is dry so im not sure where it is coming from. there is a good half inch in the rear and a little puddle on the front floor. the only thing i thought of is i switched from auto to manual seat belts and i did see a little bit of water coming from the little plastic thing that houses the old auto belt by the floor. it happended the other day and i thought it was a fluke or something but now it happened again after i cleaned it all out. any help is appreciated. thanks
water on floor
I couldn't imagine the swap from auto to manual belts causing this... There are no holes on the outside of the car from removing the belts.
In my girlfriends Neon, it leaks water from the mirror, down the door and inside the seal that way... She always has a huge puddle on her floor after a heavy rain.Simon - pimptiva.com
Here is a picture of a festiva what came with auto belts, I put manual belts in it. To do that I had to remove the two rubber plugs that plugged the holes where the manual belts go. They go through all the way to the outside. Since its in the floorboard I don't think it would leak in unless you were driving in the rain.Originally posted by SimonTuffGuyI couldn't imagine the swap from auto to manual belts causing this... There are no holes on the outside of the car from removing the belts.
