is the lighting & turn signal column switch the same ...
  • is the lighting & turn signal column switch the same ...
    between the Festiva & Aspire?
    Crickets? it seems the 323 may use the same switch ...?
      While you are at it, in your scrapyard explorations, what is the coolest and best column to have and with the most options?
      Because if you want it, and the wiring is a piece of cake really, and it can fit...
      The only big question is how many splines are at the end of the shaft
      Most people don't drive what they want at all, and never will
