Well my 1989 Automatic car which I converted to manual has some wiring problems thanks to some kind of rodent.Now the cool thing is 1989 auto car has a different distributor and coil. and wiring than manual cars or 1990 and later cars.Does anyone have the correct Underhood wiring diagram for a 1989 auto car? Anyone have an 89 auto car with the engine out? Anyone have a 1989 auto car? The Haynes diagram is not correct.Ive worked on 3 cars that had engine compartment fires and they were easier than this, Anyway I think I'm going to have to disconnect all of the Underhood wiring, lay the harness out straight and take inventory of. what's. still intact, and what's gone.
1989 Automatic wiring help.
30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.Tags: None
Check www.festivacentral.blogspot.com I put some EFI ATX Wiring Schematics from my 1989 Vacuum and Electrical manual.
- Likes 1
Thank you. Got it all sorted out already.Stupid mice.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
Thank you. Got it all sorted out.Stupid mice.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
