Seafoam
  • Seafoam
    What do you think of it?
    Good experience, bad experience, neutral?
    With What it just did for my engine, (in my build thread) I believe it’s a great thing and will probably use it on more of a constant basis now with oil changes.
    saved me from Having to take out the engine and put a new piston rings
    I've always had good luck with it. Took the chatter on startup away from my high mileage b6d (hydraulic lash adjusters).
    its great at cleaning carbon buildup and I've even had good luck cleaning small engine carbs with it.
      Nice, I just used it on my B6d too, as a piston soak and also ran it in the oil as well.
      the piston soak bumped up compression for cyl 4 about 7 or 8 psi to match the rest of the cylinders all around 183 now. But didn’t cure the stuck oil control rings like I hoped
        Wow cool post, thanks for sharing!
