Ignition key gets stuck intermittently so it won't turn to start
  • Ignition key gets stuck intermittently so it won't turn to start
    Some times it starts ok but most times it won't turn
    Duplicate post.
      Have you already tried spraying just a little WD40 in the key hole?
      Also make sure it not the steering wheel lock mechanism that is causing the problem.
        Thanks for the info0
