Turbo, wtB, AND OTHER QUESTIONS
  • Turbo, wtB, AND OTHER QUESTIONS
    Thats what I need, a BPT manifold to put on my BP, that turbo I mentioned before, I think only fits on the BPT manifold, maybe if I could get a picture of it up, someone could tell me
    Logan
    from these pictures you can see the turbo, it doesnt have a very big lip for a down pipe, I think i need a special ring clamp to hold one on, also notice the header braket for the turbo, and the turbo, the turbos is bigger. Can I get a special braket to bolt the two together???
    Logan
    Im going to post this in General discussion to, unless a admin can relocate it for me.
    Logan[/img]
    That turbo looks too big... is it off a truck?
    * Retired Festiva-er*
    1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
    B6T'ing since May 2002...
    Disclaimer: I'm a dick, deal with it.
      mazda
      The guy i bought it off from was going to use it for his 1.8 swap, but the pictures are not exactly the samesize, its hard to tell, but just the flange is like a 1/2 inch bigger than the exhaust flange.
      Might be to big, but I can't compare it to another turbo, here is a picture of it with the two together.
      sorry for the size, still getting used to hosting pics
        what are the ARs on the compressor and turbine housings? looks like a 60/64? does it have a stick-on tag with a part# on the compressor housing? If so, is it a Ford tag, with a # like E3DZ-xxxxx-xx. Looks very similar to the 60 trim Garret T3 I picked up for my BPT project. Mines from an 85 Tbird Turbo Coupe. My header flange lines up however. Which leads me to believe it might be for a turbo Escort/Lynx? I don't know who else used Garret/AiResearch turbos...
        Jim DeAngelis
        kittens give Morbo gas!!
          How do the toes in the picture attach to the turbo?
          :cat:
          Proud former owner of a shineee blue '93 Festiva L. Marvin will be missed.
            That's a full out T4 I think.
              so will it work,
              numbers on intaKE HOUSING vw m11, also 8474 224, in the middle between the oil return and take line there is a -11 430683, on the exhaust flange there is Garrett, and AR1-15 M1, also 2/87,
              Thats all the number and lettering I could find on it, Im not totally sure about its dimensions though. there is also a 124 on the intake tube where the air filter hooks up.
              Does anyone think its going to work? If so what about a down pipe, do I need a special clamp ring to clamp it on?
              I think it did have a stick on tag, but its not there now, the guy I bought it from said it was a T04E turbo, does that help
                If its a T04E that's a 500hp turbo, depending on the trim. I would not advise installation of that on a car you want to see boost below 4000rpm.
                Thanks :wink:
                  It's a very nice Garrett AiResearch turbo... probably a T3... The turbine side is setup to be a pulse converter, but your manifold is not exactly in the same arrangement... Whoever was going to use that on a 1.8 setup either had a Honda with VTEC (high revs=good CFM) or needed some classes in turbo sizing. For a BP, you want a GT28RS (disco potato) turbo. Your manifold looks like it's flanged for a T2 housing. You could probably get away with a GT2871R even...
                  Joel, the guy in the desert.
                    suppose to be a t3/t4 on the flange for manifold
                    well I dont know, i dont want to make a monster with more than 400 horses, but maybe i will hang on to this turbo for future, unless someone is interested in it for a price.
                    Anyone interested in a trade?
                    evo arnt you working on a project right nowthat could use this turbo? Got a smaller one anyone?
                    Logan
                      Mine currently has a T25 exhaust housing its a T-28 single BB. I will be upgrading soon but currently like 4 Pol want my turbo when its off.
                      You could use a T-25, most RWD SR20 came with them and alot of them upgrade often.
                      Thanks :wink:
                        Most of them are currently upgrading to a GT28RS. The first GT28RS was developed specifically for a BP Miata. A twin BB center section and more modern wheels then that T25 you've got. The GT2871R is nearly always the second choice by people with the GT28RS, so there are going to be some good deals on relatively new GT28RS on Ebay.
