Final Drive gear ratios
  • Final Drive gear ratios
    My face will be red if I missed a similar question posting.
    What are differences in the final drive ratios (ring & pinion) of Festiva and Aspire transaxels? Auto, stick, four speed, and five?
    This forum is a great resource. I hope the sometimes dumb questions I ask might be help to others as well. Thanks to the administrators and thanks to all.
    Charlie Z
    I know overall Aspires have lower gears than festivas. And the manual trans festiva is lower than the auto festiva. But the five speed has a overdrive which gives it the tallest final drive. Which is why everyone wants a five speed.
    David
      Originally posted by iceracerdude View Post
      The aspire trans a 69 tooth and the sun gear a 17 tooth. So 69 divided by 17 makes a 4.05 to 1 ratio. With the festiva trans they put a 68 tooth diff. gear with a 18 tooth sun gear to get a 3.77 to 1 ratio.
      Discuss making performance enhancements to the OEM-spec engine in your Festiva or Aspire.
        muscle_Car1
        Well, I said my face might be red. This is exactly what I needed. I'm thinking that the Aspire has a ribbed case for... a bit of extra strength, or, the rest of the case is thinner material? That mount thing should be no big hill for a climber.
        Thanks much
        Charlie Z
