sweetcheeks, I wasn't upset. I was just trying to head off an angry discussion in the General section. Just trying to move it to the correct forum, that's all.
kia pride
the kia pride have a B3 (1.3cc) and a B301 Engine option too (1.1cc)
Kia Pride Stock Specs:
Number of seats 5
Engine Front transversal
Number of cylinders 4, In-line
Engine capacity 1139 cm3
Number of valves 8 OHC
Carburetor
Bore 68 mm
Stroke 78.4 mm
Max Power 46 kW (DIN) 6000 rpm (62HP) (B301)
Max torque 103 Nm (rpm) 3500 rpm
GearBox 5 Manual
Front tires 145/80R 12
Rear tires 145/80R 12
Front brakes Ventillated disc
Rear brakes Drum
Suspensions Front Suspension MacPherson strut, Trailing-arm, Stabilizer bar
Rear Suspension Coil spring, Torsion beam, Stabilizer bar, trailing arm
Dimensions:
Wheelbase 2295 mm
Length 3565 mm
Width 1605 mm
Height 1460 mm
Track (front) 1405 mm
Track (rear) 1385 mm
Curb weight 730 kg
Max.weight 1260 kg
Fuel tank 37 liter
the 1.3 engine have 65 hp
Originally posted by Kiaporschethe kia pride have a B3 (1.3cc) and a B301 Engine option too (1.1cc)
Originally posted by HappyMomI bet he saw a Festiva with Kia badges...
Originally posted by aithanmierlol mine will be rhd as soon as i save up the pennies to get a dash shipped from europe lol
But pretty much all of Europe drives on the wrong side of the road yes :lol:Tell it like it is...not how it should be
pride 121
I would much rather put 121 badges on my festiva than pride emblems. BTW the pride tailights are arranged differently too.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
I don't even know id a RH dash would even mount up on a USD festiva beings thats the mount points are probably all different---------------------------------------------------
Originally posted by monkeyracingOriginally posted by gtd2000But pretty much all of Europe drives on the wrong side of the road yes :lol:
JimTell it like it is...not how it should be
Originally posted by GforcefdI want a right hand drive conversion, but that is going to take some time. Maybe someone from overseas will beable to atleast get me the steering rack, and dash, the rest I could modify pretty easliy.
I can have a look around for you and let you know whats available then if you like?Tell it like it is...not how it should be
