After 200k miles the engine & bay on my Festy is a mess. I've used the search tool but either their is not much written or I'm looking in the wrong place. Would love to hear your best ideas for a good cleaning.
What's the best way to clean engine & bay?
get some degreaser, spray it all over, let it sit and spray it off with a power washer.
Mike, AKA the sasquatch
Here is basically what I did when I had my own detailing business in PA:
Here is what you'll need:
* First, go out and get some Gunk Foamy engine bright or something similar. The foam will stick to the grease and help break it up, while the liquid type will just run off.
* If you want to save yourself some trouble, get an engine cleaning brush while you're at the auto parts store. This is designed for one purpose: degreasing things. You can use it for other things too; you will not regret spending $5 on it.
* old toothbrushes, rags, plastic wrap.
* If you have access to an air source (compressor with an air nozzle), that would be good, but not necessary.
* Water source with good spray nozzle. Pressure washer is not necessary, and in some cases can cause harm to some components under the hood.
* if the grease is really thick in places, try using a plastic spreader or something like that to scrape it off.
* If you're going to do the underside of the hood too, do that first, then the engine.
First, warm up the engine, but not too much, just a little warm. Don't get it too hot. You're going to be spraying cold water on it most likely, so you don't want it really hot, just enough to make the grease a little softer. Also if you have it too hot, the degreaser can just dry up before it gets a chance to work.
Cover the distributor with plastic wrap as best you can. Don't want water in there!!
Spray the front fenders, doors, windshield, etc with water. Degreaser on dry paint is not good!
Spray everything in the engine compartment with the degreaser (whatever kind you use).
If you get any on the fender, hose it off.
Let it sit for a few minutes (or follow the directions on whatever you have).
With the engine brush, just start using it to work the degreaser in, and dissolving all that grease. If you want to be finicky about it, use those toothbrushes to get the small areas.
Then hose it off with as little water as possible; just enough to rinse the degreaser off.
You may have to do it a second time if the grease is really thick.
Again, be sure to rinse any degreaser off the exterior of the car (windows, fenders, bumpers, etc)
Remove that plastic wrap, and start the engine. While it warms up, use some rags to soak up any standing water on parts. If you do have an air source, use it to get water from the distributor, spark plug wires, etc.
Close the hood, and let it warm up, and the engine will dry itself the rest of the way.
Hope this is helpful to you.
Simply... simple green:-) Get the gallon size industrial strength. Nylon bristle brushes work well in conjunction with the simple green.
Before
After
Trust me...I tried all the foams and other engine degreasers, but the simple green was the most effective and had the best bang for the buck. Here's my before and after pictures using the simple green.90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
your tellin' me that simple green will transform my wore out old b3 into a clean, repainted slightly modded b6!!! I'll take a transport truck load........lol!!!
To get the grase off, after 20 years a HD mech, FORD degreaser is the best, warm er up, and hit it it with a hotsy....everything is spotless....I have used this product at KENWORTH for years, and we have tryed everything i think!you want to blend in?, drive a honda
92l festy car, original owner.
2008 xls mitsubishi outlander
1987 nissan diesel truck
I use Purple Power manufactured or at least labled by Castrol. Also available at Wal-Mart. Some knock offs are on the market, nothing as goosd as the Castrol Brand.Originally posted by joebreck117 View PostPurple Power from Autozone.
Be careful, it etches Aluminum
Once a year for all my cars....the night before I back the car in the garage...early the next morning i push the car out of the garage far enough out of the garage so I can pop the hood.
Sray the entire engine and bay with purple power...±1½ quarts...in a spray bottle with a streaming nozzle...buck or two from the hardware store.
Let the engine sit for about 15 minutes or so....rinse it down with a garden hose. Let the car sit another 4 hours or so before I attempt to start it up.
Works great...the real trick is to keep up with it and repair any leaks ASAP.Joe Lutz
The SKATE ..... 1992L 5spd
Hi I have one question about how to clean your engine. What all dont you want to get wet. The distributor was mentioned what about the alternator mine is VERY dirty so im wondering if by scrubing and spraying it will i wreck something. Or also the wiring. People have said to me "dont get the connectors wet it will fry your whole harness".I'm not sure that's true but id rather not find out the hard way.Any info would be great
thanks
TimTim S
mobile steam
I just phone a mobile steam truck and have your engine cleaned behind someone else's factory somewhere.
I learned the steam trick when my boss had us talk a salesman into lending us a brand new Steam Jenny for evaluation before buying and then proceeded to clean every press in the factory and then everyone's car engine. The steam blasted off all the grease and grunge without chemicals. However, after the evaluation was complete, for some reason we decided not to buy the Steam Jenny because it wasn't needed any more. Tsk, tsk.
