i know the stock bore of a b3 is 71 mm (2.8 inches) is there any way to take that out to 87mm (3.4 inches)?
Extremely weird question and probably ridicules
(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
New: Tires, Axels, Front Wheel Bearings, Fuel Pump, Valve Cover Gasket, Carb Rebuild, Timing Set, Belts, Shoes, Distributor, CapRotor, Wires, Plugs, Coil, Grant 11" Steering Wheel, 3700 Watt Stereo System-6 1/2 Infinity speakers, Infinity tweeters, Almani 12" subsTags: None
I don't know how thick the cylinder walls are in a B3 but I'll bet less than 0.30".
So I don't think that's possible!
And even if they were thicker I don't think there'd be enough wall to actually run for very long!
Anyone know the B3 wall thickness?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Found this thread regarding boring out B3.
- Unknown
- Quentin Crisp
- Bumper Sticker
I don't think i've ever heard of boring a B3 more than .030" over. If memory serves, the bore is the same for all US market B series engines and the stroke varies between them. I would think that that large a bore increase would go right through the cylinder walls to the adjacent cylinders. Why increase bore? An increase in stroke gives you the big power gains, and if that's the case, why bother stroking a B3 when you could have a B6 or BP?Last edited by Axlander9289; 10-15-2008, 10:57 PM.Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
i figured, i just happen to have a set of EXTREMELY expensive dome pistons, and nothing to do with them lol(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
B3 and B6 engines have the same stroke, different bore. this is due to a different casting allowing the larger bore.Originally posted by Axlander9289 View PostI don't think i've ever heard of boring a B3 more than .030" over. If memory serves, the bore is the same for all US market B series engines and the stroke varies between them.
to answer the original question: No, at least not without siameseing the bores using liners and totaly removing the original bores.Trees aren't kind to me...
I think FB71 must have this on his clipboard to post each and everytime this question has come up
Quote "no, the block castings are different. The cylinder liners would get way too thin if you bored out the block for b6 pistons." Unquote
I found it multiple times over 8 pages that came up doing a quick search. :razz:Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
^ 3.4" is no where NEAR a B6 bore size, it's even bigger than BP pistons!Trees aren't kind to me...
yeah they are for a 2.0 engine and actually they are .40 over pistons lol so its even bigger(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
somewhat bass-akwards^^^
B3 and B6 share the same stroke (83.6mm), different bore (71mm vs 78mm)
B8/BP bore is 83mm. The B8/BP is longer, because the bores would have bumped into each other over about 80mm.Jim DeAngelis
so what ur saying is it would be impossible to make a stroked out b3 using a bp crank(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
correct. the BP crank has the rod and main bearing journals spaced too far apart to even think about fitting it into a B3/B6 block.Jim DeAngelis
but with a bore of 83 is it feasible that the pistons would at least fit? lol(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
that's still a difference of 4mm, or 0.16 inches (0.125 is 1/8 inch). That's more than the thickness of most cylinder walls... so far, you're talking custom machined, solid billet block...Jim DeAngelis
