Since there are so many doing the SHO V6 swap, does anyone know about swapping from a 98 SHO (3.4L V8 )?
SHO Question
all i know is it's auto ONLY if you go that route.Trees aren't kind to me...
I heard the V8 version is not as reliable or as powerful"FLTG4LIFE" @FINALLEVEL , "PBH"
stay away from the 3.4L. Cam sprockets shear off the cam, causing valve clash with the pistons. They're underpowered, and parts are literally non-exisitant. That engine is best relegated to a museum at this point.Jim DeAngelis
I've heard the engine are fairly reliable if the cams have been modified to fix their problem. I haven't done much research on them though, so I don't know about other reliability issues.91 lx 4d hatch - first car and would be my father's dd if he would fix the waterpump
91 lx 2d hatch - parts car
92 lx-e - the quick, beat-up rustbucket
98 se - the luxury dd
in search of a festy...
Going quickly in a slow car is more fun than going fast in a fast car, cause anyone can go fast in a fast car, but you take a car that is essentially not that powerful, and make it do things that its not supposed to be able to do, well that's where the real fun is. - Jay Leno
The SHO V-8 was the worst design from the SHO series. Jumped valve timing causing serious problems, was slower than the V-6, only came in automatic, and dogged its way through life. If you're gonna do a SHO swap just an early V-6 that has a 5spd as well. It will be very fast and lots of fun to drive, just like the SHO taurus was."If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
correct. you either need to locate cams that haven't slipped at all (most have migrated a degree or two off) or hve your cams dialed in, then either one needs to be properly welded up (sprocket to camshaft). The friction weld Yamaha/Volvo experimented with didn't work too well, which was the major source of failures.Originally posted by TrueBoolean View PostI've heard the engine are fairly reliable if the cams have been modified to fix their problem. I haven't done much research on them though, so I don't know about other reliability issues.Jim DeAngelis
There is very little aftermarket for the v/8 sho, some guys supercharge them but thats about it.
The design is not bad but not anything great either. All the neat stuff that made the v/6 so great was left off the v/8. Once they are dead thats about it, you cant even get head bolts for them, they are the throw away "torque to yeild" style.Last edited by NovaSS; 11-24-2008, 06:18 PM.money pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
Originally posted by Futurefesty90 View Postsince we're talking about cam slipping, tell me why on earth ford used a fiber-tooth cam gear on my 85 302ci
to make them quietmoney pit
