I think I've shared this before, but I'll share again since I ran into this problem again today. Most of you know that after time, Festiva wheels like to rust onto the hub. Then when you go to remove the wheel they can be nearly impossible to remove. I was rotating my tires today, and the rears were stuck on pretty good(haven't been removed since I bought new tires last fall). The fronts were fine because I had the wheels off this summer when I did my brakes, and I did my little trick.
To fix this problem, when you have a wheel off, before re-installing, coat the mating surface on the back side of the wheel(you can see the outline of the mating surface) with anti-sieze compound. I do this everytime I have the wheels off. I also put anti-sieze on the lugs. If fact, the older I get, the more anti-seize I use. I use to buy it in little tubes, now I buy it in big jars that have brushes for easy application. Pretty much when I do any auto work, I put the stuff on just about every bolt before re-assembly.
