Saturn head gasket gone....I think
  • Saturn head gasket gone....I think
    I have oil in cylinder one and 3.#2 is fouled and 4 is good.It will not start at all.I just need it to run temporarily,so,I was thinking of sucking the oil out of 1 and 3 and using non-foulers to try to get it to run..Any suggestions ? Turns over great.Ran 2 days ago,but,hard starting.It is going to the mechanics,but,I want to see if I can get it to drive there.It is getting a used engine.It is a 2000 dohc sl.4 door if it matters.
    remove the plugs and spray carb n choke cleaner in there. then crank it with the plugs still out. this will dilute the oil i there and throw it out the spark plug holes. throw in new plugs (with or without the no foulers) and fire it up. should run for a few miles atleast.
    88 mustang 427 stroker garrett t-76 turbo best run 8.86@ 151.56
    91 red gl festiva the $50 daily driver <--toast
    WANTED 78-80 FORD FIESTA (PREF GHIA)
      Thx.I will try that.
