converting to 13" wheel on 92 Festiva
  • converting to 13" wheel on 92 Festiva
    I want to convert my 92 Festiva from a 12" wheel to a 13" wheel. What wheels are compatiable? Do I nee different lug nuts?
    check this out:
    Discuss improvements to your Festiva or Aspire in the handling, braking, wheels and tires areas.
    festiva has 4 x 114.3mm.
    -Aspire brake swap COMPLETE!
      i would recommend doing an aspire brake swap, because then you will have to upgrade to a 13" and the lug pattern is 4x100 i think so you will have more options on wheels
        I can tell you haven't had the rims off before. They are studs
          I have had mine for a year now, sitting in the driveway waiting for an Aspire swap. Even bought HX wheels for it.
          I wish oh I wish I could find some swap parts.
          Rodney
          1991 FI 5 Speed Aqua Blue
