Dunno where to ask this
  • Dunno where to ask this
    Does anyone know what the 2 grooves on the roof are for. They don't appear to be made of metal...
    (mods, move this to where ever it should go... I'm just not sure where that would be?)
    Mon arme a moi, c'est un stylo.
    I would think possibly the Custom Interiors/Exteriors Forum. I dont think they really do anything. Possibly cover some type of seem. I bet I know who would know for sure though. FB71, he knows everything. Well OK maybe not everything, but quite a bit anyways. :p
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      I was thinking of drilling into them to mount my custom roof rack.
        Rain gutters
          That seam is where the outer roof panel is seamed to the body sides. The seam may be spot welded or roll welded and then the seam sealer hides the joint.
          I wouldn't be drilling in that seam, you might wide up with a water leak.
            ditch molding
            He is correct. That is called the ditch molding. Depending how they are feeling on Monday morning, the roof should be placed on straight so that the the gap in both of the ditches are identical before they weld. Worst case, they have a bad hangover and they are off a little. One side would be wider than the other. The other a little narrower. Good place to check to see what day the car was made on. Dodge Durangos had six moldings to fill the gaps, but only two part numbers. They always have perfect gaps. Just don't get in an accident and order a replacement ditch molding.
              that is correct the seam appears to be rolled I have my moldings off at the moment if you want a picture
              92 GL - parts car
              97 aspire - parts car
              87 323 DX - daily driver
                Do you really believe this?
                  Back in the day before robots built cars, this was true for sure!!!!! Same for house builders too. :-)
                    slightly
                    Like I said before. For the Durango, Chrysler ordered a narrow for one side and a wide for the other with just a phone call I believe the difference was about +/- .010". Or, because the moldings were handed, a wide for the left hand and a narrow for the left hand. Ocassionally, they would run nominal - nominal. But most of the time they phoned to expedite (fly at their cost) the alternate parts. We kept telling them, that they had them in their warehouse, but they didn't know which one. Guess who paid for it? You and every other taxpayer.
                      They simply cover an in-expensive body joint...which adds a little web strenght to the car.
                      Joe Lutz
                      The SKATE ..... 1992L 5spd
                        You just need the factory roof rack , then it wouldnt be a problem.
