Is there anyway to tell if your cat converter is good or not. If it isn't, would it be better to buy a new one, or do you think taking a chance on one out of a salvage yard what would odds be that it is bad. Does anyone have one they would want to sell if you know for sure it is good. I have a 93GL. FB71 said when my car didn't pass first time with the HC so high, that very possible that convertor is bad. If i put new one on, what are odds that it would lower HC.
Cat Converters
Tags: None
odds are good, but with such high HC, i'd think the old cat may have melted a bit. have you pulled it out and inspected the hunnycomb (sp)? seeing that you're not the original owner, ther MAY be a missing component of your cat... that would cause high HC as well. i'd also verify that your O2 is working properly (use a DVOM and watch the voltage swing).Trees aren't kind to me...
i recomend a visual inspection before swapping, if it's melted and in pieces, don't swap in your spare! the same thing will happen to it.Trees aren't kind to me...
An easy way to check one is un bolt the fromt exhaust and put a shop vac on the tailpipe if it revs up like it has a blockage then your cat is not free flowing.-Greg
Redneck Engineer
FOTY - '09
Euro, he doesn't have a running/clog issue, he failed emissions inspection.
Arty, his HC aren't that high. He blowing about what should be expected with no cat, only 2-3ppm. I suspect the cat is either hollow, contaminated, or just dead. In any case, MHB, replacement should be your primary course.Jim DeAngelis
dang, I'm jealous!!! I skirted Moab when I rode my motorcycle cross-country in '05. What I saw of Utah was stunning!!!Originally posted by milehighbear View Postty guys for input. And thank you FB71, i'm just going to go ahead and get a new one after i get back from Moab, UT in about week. Got a granddaughters wedding to attend plus we are going to camp out for couple days and enjoy country.Jim DeAngelis
cat
Very strange! It should run better if it was clogged, and the same if it wasn't. I'd check to make sure the exhaust is all hooked up; then look for other unrelated issues; i.e. did he do any other mods when he did this? Changed timing belt for example, but it's a tooth off?
All poor-running issues boil down to four factors:
air
fuel
spark
timing (either valve timing or ignition timing)
One (or more) of 'em's not right.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I don't know about the laws where you live, but where I'm from, junkyards aren't allowed to sell used cats; it's illegal. If your cat is bad, you have to replace it with a new one. Also, most of the shops where I've check won't install a used cat on your car...Originally posted by milehighbear View PostIs there anyway to tell if your cat converter is good or not. If it isn't, would it be better to buy a new one, or do you think taking a chance on one out of a salvage yard what would odds be that it is bad. Does anyone have one they would want to sell if you know for sure it is good. I have a 93GL. FB71 said when my car didn't pass first time with the HC so high, that very possible that convertor is bad. If i put new one on, what are odds that it would lower HC.The left lane? Are you crazy!!! I never drive in the left lane...It's full of freaks driving the wrong way and charging right at you!!!
This is true in Pa. too. Unless the law has changed. Had a guy sell me on for the Subaru turbo out of a big yard that was like new for $20.00. He wrote it up as a tail pipe. Saved me a big pile of money!Originally posted by Pocket_Rocket View PostI don't know about the laws where you live, but where I'm from, junkyards aren't allowed to sell used cats; it's illegal. If your cat is bad, you have to replace it with a new one. Also, most of the shops where I've check won't install a used cat on your car...Is that someone there ??? 1981 VW diesel pickup---1988.5 Suzuki Samurai tin top---1993 Festiva---1974 Bricklin SV-1 ( very thirsty basket case)---2003 Tracker(bells and whistles)
