Best way to remove the side trim strips? Adhesive remover? Pull? Scrape?
Remove side trim
Remove side trim
1993 Ford Festiva L ($650)
Mazda 1.8L BP - PaceSetter Header (in progress)
Aspire Swap - 15x6.5 wheels, 205/50/15 tires
>> Photo Album <<Tags: None
Maybe all of the above. As a pre-treatment, squirt them with WD-40 or GooGone. You can use a plastic scraper + pulling to get them off, or just pull. The scraper and/or elbow grease will get the rest of the old glue off.Originally posted by jcbgrady View PostBest way to remove the side trim strips? Adhesive remover? Pull? Scrape?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Pulling a piece of piano wire or strong fishing line behind them works well too. Then just use some goo gone (or your choice of glue remover) or my personal choice, a rubber wheel.-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
Cool, thanks guys!
>> Photo Album <<
