Any of you ever used or heard of this company and their ez bend brake tube/lines? From what I have read its getting pretty good reviews, bends easily by hand, can be custom made in the length you want with the fittings you want, is relatively cheap, and yes I know thats not much better than regular brake line BUT WAITit supposedly resists salt & rust almost if not as good as stainless steel? I am thinking about using this for my hard brake lines with the stainless steel braided at the wheels instead of rubber. Go to brakequip.com to look at it.
Brakequip Ez bend brake tube/lines
Brakequip has been around a long time. They make good stuff.Festiva: Because even my dog can build a Honda.
My first impression is that it's a snake-oil type thing. I'd have to hold a piece of it and bend it by hand to really give you my thoughts. It could be awesome though. I wonder if there's a way to get a sample piece.-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
Are you talking about this product?:
Whether using stainless or EziBend tubing, BrakeQuip offers tubing designed to withstand the harshest of environments while also being easy to work with.
NAPA sells a similar or same product as do other parts stores. I've used the NAPA tubing. It's easy to form without bending tools. It's about twice the expense of standard brake tubing.
Don't even think of trying to sub this tubing for flexible rubber hose.
So, how'd it go today? Can't remember if you were starting on the brake lines, or just doing the front end stuff today. Other than not being able to see what they charge for their stuff, what they have looks pretty decent to work with.
1989 L - 247K miles Slick
Originally posted by batstiva View PostSo, how'd it go today? Can't remember if you were starting on the brake lines, or just doing the front end stuff today. Other than not being able to see what they charge for their stuff, what they have looks pretty decent to work with.Last edited by xlence; 08-15-2009, 09:07 PM.
Good to hear you got the Festiva back up and ... stopping? and that you made it out safe!-Caleb
Yeah, I saw you came back and finished it, so I deleted mine.
Originally posted by pr0nst4r View PostGood to hear you got the Festiva back up and ... stopping? and that you made it out safe!Last edited by xlence; 08-15-2009, 09:22 PM.
It's ok xlence, I've done similar things. I once test drove my car around the parts store parking lot because I was so paranoid I'd have another coolant leak. I had replaced nearly all the lines at that point (was too broke to replace them all at once, or rather, didn't want to spend the whole chunk of change at once. It wound up costing me more in the long run.) and was carrying gallon jugs of water and a couple extra bottles of water wetter in my car.-Caleb
Most major auto parts chains carry this type of line now, commonly known as Poly-Armour. It's very maleable and the coating makes it very resistant to corrosion. I started using this on a master cylinder conversion I developed for the early Econoline PUs and vans. I had a very tight spot that needed a 90 degree bend right out of the MC but could not bend a standard line that tight. I can use this line, take a piece of 3/16" rod in my vice and bend it 90 degrees behind the fitting with my hands without collapsing it. I also need a metric 12 mm fitting and bubble flare at the MC with a inverted flare and 3/8 x 24 SAE fitting on the other end. These are available right off the shelf. Very nice product.
Dennis in Oregon
