14 inch rims
  • 14 inch rims
    sorry if this is a repeat I did search but wasnt finding anything. Does anyone have 14" rims on and if so what tire size is recomended?
    -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
    -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
    Tire size calculator | 1010Tires.com is the largest and most trusted online and retail tire company.
      geo storm wheels
        I have 185/60x14s on 6" wide rims. Just barely works; make sure you have good rear struts. You might want to roll your rear fenders for more clearance.
          195/45x14 is the tire that is nearly the same diameter as stock. Toyo Proxies
          If you go up to 185/60x14 you get alot more selection at a considerably lower price.
          http://www.tirerack.com/tires/TireSe...er=14&x=22&y=6
          And in that size Ive read alot of good reviews of the General Tire Altimax HP, not just at Tire Rack but other places as well.
          But if youre speedo is saying 60 youll actually only be doing 55.
          - Unknown
          - Quentin Crisp
          - Bumper Sticker
            I have the Toyo Proxies in 195/45/14, they are great tires, but expensive and hard to find. Just for reference in the future, is there any rubbing with the 185/60/14? That's probably what I would go with, it would be way cheaper and easier to find.
              Originally posted by bravekozak View Post
              Do you need spacers to use these wheels?
              Is that someone there ??? 1981 VW diesel pickup---1988.5 Suzuki Samurai tin top---1993 Festiva---1974 Bricklin SV-1 ( very thirsty basket case)---2003 Tracker(bells and whistles)
                Aspire conversion
                No spacers. Just the Aspire suspension.
                I found a set of spacers on a Festiva at the wrecker's.
                If you were putting on some really wide rubber, then let me know.
                  Are these bolt on spacers that you found? Or just spacer plates? Are they for the factory festiva hubs?
                    spacer plates
                    They are spacer plates for the factory hubs.
                      I need spacer plates for my Estrellas, on the rear only. The offset is 35mm I think; I am using about a 1/4" spacer. The rims are 6" wide. For 5.5" or narrower rims you probably won't need spacers on the rear.
