37mpg.   I was getting 44 or 45mpg with the B3.  I have noticed the vacuum advance may not be working properly.  Attach a hand vacuum pump and you can draw a vacuum and advance the distributor, but it leaks down quickly.  Should hold until released.  This is distributor that came with the Japanese B6 and only has the one vacuum connection.  I will have to try the one off the B3 or might experiment as I have an old adjustable Chevy vacuum canister for V8 distributor, you use a little allen wrench to adjust the advance amount.  Take some adapting to use it with this distributor.
Oh and this engine would really appreciate a 5spd tranny. Its sweet spot with the 4spd seems to be 50mph. It just easily loafs at that speed without seeming effort, uphill, downhill, all around the hill. Dont have a tach to know what rpm that is. But with the extra power over a B3, could pull overdrive easily.
Fixing vacuum advance should get me back over 40 and overdrive probably back to 45 or so.
