i was wondering what will make the stock b3 go faster and give more power,what diffrent mods will make the b3 engine faster, and is there a way to get the computer chipped so it can rev up to higher rpm ? cause i know in hondas there is is..
what is the max power a festiva can do with mods?
Come on youve been here since February. Search a bit, theres some stuff on here about modding the B3. Cams and such are available from FMS. Youre not going to get the kind of power youd get if you did a swap though.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Put a b8 in it and be happy
-Greg
Redneck Engineer
FOTY - '09
Cone filter, cam, valve work, headers, free-flow exhaust...will not give you as much power as a simple and much cheaper B6 swap. Starting with the B6, you can then do lots to it for even more power. Go that route, or even more motor.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
