well, went to yard today and got a 1994 escort wagon wiper gear and arm..hopefully those parts were all i need...i stripped a wiper motor right on the spot.and decided to cruise the foreign section for mazda stuff...found a 1991 protege with engine in it 1.8 BP ....sadly the spark plugs had been removed and engine was full of water :-(.....anything else thats useable from a 1991 protege ?
todays JY trip question
1992 festy GL, loaded, stock, 79 K
1994 Ford ranger - 2.3 I4 - 5 spd.
1999 Ford ranger - 3.0L V6 - 365 K and rising ! ( shooting for 500 K )
2000 Ford F-350 dually crew cab - 4x4 powerstroke !
2003 Ford Focus SVT - supercharged
2005 Saleen N20 Focus
" If it hurts when you do that, Dont do that !!! " - mikec
" Age and treachery will always overcome youth and skill ! " - unknown
" Three can keep a secret, if two are dead ! " - Carlos MarcelloTags: None
thanks brian....i go thru this yard fairly often, so i will check out the mirrors next time im there...i only took the white gear and arm from the wiper motor, so i hope thats enuff...1992 festy GL, loaded, stock, 79 K
yep....you got enough"FLTG4LIFE" @FINALLEVEL , "PBH"
you pull it / speedway auto parts on rte 30 in chicago heights / ford heights.....they dont have much in there...not a single festy...i went for stuff for my ranger pickup but decided to cruise the yard...btw, thanks GD for the confirmation on wiper parts...1992 festy GL, loaded, stock, 79 K
thanks wes....will check them out too...maybe the motor would be a good parts / rebuilder motor if its cheap enuff..depending how long the waters been in it....looks like the car is all there...1992 festy GL, loaded, stock, 79 K
