how hard it it to remove the dash?
dash Question
dash Question
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
It is not that hard you just need to remove 5 bolts, 9 screw, the 2 plugs behind the cluster the speedo cable plug, the 3 vent control wire and a couple of plug on the driver side and maybe a couple of other misc. plug that I forget about.
it looks hard when your looking at what all you have to do...but its really not all as bad as it sounds.1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
1997 Ford Aspire, MTX, Red, B3E - "Eggy" (RIP)
1989 Ford Festiva LX, ATX, Maroon, B3E - "TBK" (RIP)
1991 Ford Festiva GL, ATX, Red, B3E - "Festiva GT" (RIP)
good to know its the last piece to my puzzle....Frankie
It harder to reinstall . One problem with removing the dash is getting to the bolts on top of the dash in the corners up by the windshield. Not enough room for a socket. I bent a 10 MM wrench just for fitting those two bolts. If you arent careful you can break a windsheild.sigpic
I had no problem doing this with a u-joint and a small 1/4-inch-drive 10mm socket.Originally posted by freshtiva View PostIt harder to reinstall . One problem with removing the dash is getting to the bolts on top of the dash in the corners up by the windshield. Not enough room for a socket. I bent a 10 MM wrench just for fitting those two bolts. If you arent careful you can break a windsheild.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
what about putting a vise grip on the 10mm bolt and have the angle on it on the 2 top dash bolts??? i've thought about that if i ever remove the dash... simontuffguy has removed many-a-dash, he'd know too..
-Aspire brake swap COMPLETE!
Originally posted by TominMO View PostI had no problem doing this with a u-joint and a small 1/4-inch-drive 10mm socket.
Well sure, anyone could do it the easy way.
Originally posted by TominMO View PostI had no problem doing this with a u-joint and a small 1/4-inch-drive 10mm socket.Gotta admit it though Fresh. Its good info. I know itll probably come in handy when I pull the dash in Crusher for some modifacations.Originally posted by freshtiva View PostWell sure, anyone could do it the easy way.
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by MONSOON View PostGotta admit it though Fresh. Its good info. I know itll probably come in handy when I pull the dash in Crusher for some modifacations.
Let me know how that works out for you.sigpic
There is another alternative to u-joints or vise grips on a socket.
Sears & others sell a 10mm (and plenty of other sizes too) ratcheting box end wrench that has a pivoting head.
There are even 2 versions of that.... one with a "floating" pivot head and another with a "lockable" pivot head. I've used both & found that the locking head is easier to use, as the floating one will often do an undesired pivot away from the bolt head when you put some torque on it (at some angles).
Just another option.Last edited by sam.1956; 09-26-2009, 11:34 PM.
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
