Have a 1992 Festiva "L", 5-Spd that runs fairly good. My son and I are working on it togeather. Dents and dings in the body. Poor interior with pounds and pounds of junk. inside. A mechanic had it for transport only.
It has: New plugs, new struts around, new bearings, new batt, new starter.
I've changed oil to 10/30 Valvoline, run fuel injector cleaner thru it, sprayed the throttle body, put in a K&N. Using OEM style 12" front tires filled with Nitrogen.
Problems: 1. High beam headlights will not come on. Low beams work.
2. Main fusable link blew. Replace it with 14 AWG wire (Not happy with this).
3. Other fusable links intact but look old. Would like to replace.
This is a long term project. Unit will be towed behind my old class "A" Motor Home. The unit runs fairly strong now, gives many a small 4-banger a fit from the light. I'm an old "hot rodder" who's been out of the sport for years. Help with parts and advise requested. Oil advise...5/30 at 180K Miles?
"DRIVE ON... ARMY"
"DRIVE ON... ARMY"
