I know that bad things can happen if your lower control arm ball joint pops out. My question is, is there also a possibility of catastrophic failure with the tie rod ends? Can they ever pop out if the rubber boot is shot and they get too worn? Or are there other symptoms you can diagnose from the driver's seat, like rattling or vibrating?
Tie rod question
Tie rod question
Tags: None
well they can definitely pop out.....have had it happen. But if you are paying attention you will definitely have signs leading up to the pop pop popping....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
So if they pop out, you do lose steering ability for that wheel; can you safely bring the car to a stop? And what are the signs it's getting ready to fail?Originally posted by GenevaDirt View Postwell they can definitely pop out.....have had it happen. But if you are paying attention you will definitely have signs leading up to the pop pop popping....lol90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
steering is questionable.....vibrating....wheel wobble....loose and wandering steering"FLTG4LIFE" @FINALLEVEL , "PBH"
Thanks. I like the way we are cycling back and forth between these two threads!
lol...yup....but I am using a tricycle"FLTG4LIFE" @FINALLEVEL , "PBH"
^^ Someone needs to get a picture of that.
1989 L - 247K miles Slick
