Question
  • Question
    Are ecu and pcm the same things?
    If not, where is the pcm located?
    ENFORCER - Midwest Festiva Inc., Iowa
    #2 .....Cheesehead
    #3 '91 White - Donor Car
    #4 .....Montana Project
    SOLD----Levistiva for $1500
    Bought her back for $450
    In a nutshell:
    ECU= engine control unit (strictly engine)
    PCM= power train control module (also controls trans and other functions, etc. depending on the car and model, mostly newer ones).
    Festiva does not have a PCM, just an ECU
      Originally posted by blkfordsedan View Post
      In a nutshell:
      I'm talking about that Aspire from the other thread you responded to. I've been fiddling around with it, checking the connections, like you said. In doing so, I jumped a connection and the fan turned on. While reading the wiring diagram, I see that the pcm influences the opening/closing of the circuit that turns the fan on. After all tests conclude that everything is fine, then the pcm is to blame, per the Haynes manual. If so, then I have a spare car with a spare pcm that is just dying to be replaced. Unfortunately, I don't know where it is located, the pcm that is......I know where the car is located...LOL!!.
      #2 .....Cheesehead
        Are you sure?
        Actually it probably isnt hard to find , just have to remember which pile of snow its under! :razz:
        - Unknown
        - Quentin Crisp
        - Bumper Sticker
          Sorry, didn't make the connection (no pun intended). According to the Haynes, the fan is controlled by a temp sensor, not a thermo-switch like a Festiva. I thought you said you unplugged the thermo-switch and the fan didn't come on..........I'm not sure it's supposed to work like that on an Aspire since it's not a switch that grounds but rather a sensor that works on resistance. Did you check the actual resistance on the coolant temp sensor? I would think if the sensor was bad you would experience other problems and the CEL would come on.
          To answer your question, I believe in this case the PCM is the only computer and controls everything. According to Haynes, it's located behind the instrument panel (dash?) on the passenger's side.
            as far as i remember the aspire only has the coolant senor for the gauge. but its been awhile since i had the 1.3
