Hi all, okay so here is my problem my parents have a 1994 chevy lumina v6 3.1. for about a month while driving it it would just have a random miss, then all of a sudden while driving it it would just quit we would have to put it in nutural then restart it. well the whole time we were trying to figure out what the problem was first we changed the ignition control module(didnt fix the problem), then all of a sudden yesterday it was warming up in the driveway and it just quit running, when you would try to start it it would backfire out of the intake, and act like the timing was way off. I unhooked the neg. battery cable went inside and about a hour later I hooked it back up and it started fine and idled fine, but as soon as I touched the gas it died and then resumed the above, (wouldnt start), so me thinking that it was the ecm I got one from a running lumina and hooked it up it started fine and idled perfect, then I hit the gas and it spitt and sputtered horrably then died the same as above(with a known to be good ecm). this is the part where I ask what do you think it is, my next choice is either the fuel pressure regulator, or maybe a sensor? any help is appreciated -Daniel
p.s. this is our only vehicle so by it not running is making getting to work hard (4 people 4 different jobs)
