My Festy just turned over 193k and I've never had a car with this many miles on it except for my F-Superduty rollback that has 400k on the clock. I don't think the Superduty counts though because it has had a crate motor installed at some point before I got it. Anyway, my car is a 5 speed and I was wondering what is the life expectancy for clutches in these cars? When I got the car I changed the timing belt and water pump due to the mileage. All the other stuff I've fixed has consisted of replacing factory parts as well....struts, CV axles, stuff like that. Based on this I'm assuming the clutch is still the factory unit too. I'm a big fan of preventative maintenance and I like to fix stuff before it breaks so I'm wondering if it's time to start thinking about swapping the clutch, pressure plate, and release bearing.
Should I be worried?
