would anyone want one of these? i can make them no problem
to make it fit with the gauges i had you have to hack the dash up a bit... it only took 10 min with a dremal...
installed
and the gauges lit up
if you want i could sell it a a package deal with everything you need to put it in and ill even wire up a harness, all you would need to do is cut the dash like i did, put in the sensors and wire up 6 or less wires... (power, ground, lights and the 3 sensor wires, if the gauges are mech like a vacc/boost gauge then there is no sensor wires...) the store that i buy them from has vacc, vacc/boost, water temp, oil pressure, oil temp, narrow band A/F, volt and rpm... if anyone wants one let me know...
installed
