I thought this article from 'American Iron Magazine' was a useful shop safety FYI.
Common Cleaners Can Turn Into Poison Gas
Wow !!! :shock: Thats some wicked stuff.
Phosgene gas = dirt nap
Yeah, and there a lot of it made for the synthesis of other chemicals.
One of the chemical weapons used in WWI.
Think it banned as a weapon now.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Thanks for posting that!
I'm just learning to weld. I heard about the carb cleaner trick for cleaning, but after reading that, I'm going to be ultra paranoid about using anything! :shock:Festiva: Because even my dog can build a Honda.
Just use some alcohol. It's safer. I use it on stuff I weld.Originally posted by FestivaFan View PostThanks for posting that!
I'm just learning to weld. I heard about the carb cleaner trick for cleaning, but after reading that, I'm going to be ultra paranoid about using anything! :shock:-Greg
Redneck Engineer
FOTY - '09
Just don't use chlorinated solvents.Originally posted by FestivaFan View PostThanks for posting that!
Ingredients are on the side of most cans.
If the contents aren't listed on the can don't use it!
There are a lot of non-chlorinated cleaners now made which are safer for humans and the environment.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Exactly. Most brake cleaners will state if they are non-chlorinated. It is in big letters right on the front of the can.Originally posted by Pu241 View PostJust don't use chlorinated solvents.
Also, always use the right cleaning solvent for the work you are doing! Carb clean is for carbs, brake clean is for brakes, and degreaser is for your engine and engine bay. There is a reason why there all these different types of cleaners.The Festiva Store
