I have this 88L with a manual, I was told when i bought it that the clutch was bad. ok, no biggie.
I have done lots of clutch replacements. I first drained it and it was 90w, is that the correct fluid?
I figured it was gonna be ATF, but I know little about festy trannys, i figured it's a MAZDA trans? Ok then I see a switch on the front with 2 green wires and a plug that isn't plugged into anything and no idea where it's supposed to go.
Then I notice a plug under the right axle with two wires sheared off right at the switch, I am assuming that is the reverse light switch and why my reverse lights don't work.:confused1: kinda looks like somebody replaced an axle and pinched them while trying to get the axle popped out.:dink: Which I failed to get out myself and did the clutch with it still in the trans, that was a ball. The rain came in and I didn't get finished, so I figured I would ask while everything is still drained. Oh, and a retard question, where do you fill them back up and how much do they hold?:tard:
