OK so I had a couple of good finds at the junkyard today. I found the passenger side window regulator that I need in great shape, a great battery tray, and REAR WIPER WITH SPRAYER!! So stoked! Now for the questions, where is the reservoir for the rear wiper? Or does it use the same one up front? And also the hose for the sprayer was not hooked up to anything (just hanging out in the hatch) so that makes me think that this car had a swaped hatch. And I didn't see a seperate washer switch for the rear, does it use the same or is this just a hatch swap? O and it had an auto if anybody is looking for one around KC. Off topic of important stuff but where should I try and pry to get the chrome Festiva badge off the rear without hurting it? Thanks in advance!!
Junkyard findings, need help!?
Nice finds. The rear washer bottle is in the passenger side quarter panel. If you need on I have one for you. I also have a couple window regulators. The rear wiper switch also serves as a washer switch. As far as prying on the emblem just use a razor blade and be careful. I've seen some that had 2 pins and some were just stuck on with tape. If it has the pins you'll have to get them out.
Did they still have what we talked about there?-Greg
Redneck Engineer
FOTY - '09
I checked and the motor cavity was completely bare. Someone probably got a good 100K turboed motor by the looks of it.Originally posted by eurotiva View PostNice finds. The rear washer bottle is in the passenger side quarter panel. If you need on I have one for you. I also have a couple window regulators. The rear wiper switch also serves as a washer switch. As far as prying on the emblem just use a razor blade and be careful. I've seen some that had 2 pins and some were just stuck on with tape. If it has the pins you'll have to get them out.
Did they still have what we talked about there?:festiva::newb::festiva:
Tranny? Mid shaft?-Greg
Redneck Engineer
FOTY - '09
sneaky sneaky93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
