Diagram needed
  • Diagram needed
    I need a diagram for a 94' probe GT, basically what i need is a diagram that would look like a picture of the ECU connectors with every pin labeled (<- sp?)
    I have 2 identical wires on the same connector and i need to identify which one is which
    Thanks in advance
    I will get it for you in a couple of minute.
      Awesome thank you Maxim
        I can see them but I can't send them here
          any way to email them to me?
            I will be here all night so if you want me to answer some question I'm here or I can phone you if you want.
              No I can't copy and paste . I've try sorry
                i'll get a picture to make it easier lol
                  OK I give a try to this (But I'm sure you need to login)
                    Here are pictures of the 3 ECU connectors
                    This is the connector to the far left, both pins i circled have a blue w/ red strip wire, which one is "kapwr"?
                      the white one. Open your MSN we are going to chat and I may help you a little bit more than this.
                        Thank you very much!! i should be able to get my festiva running this weekend
                          Glad I could help you. Go on MSN and I will help you a little bit more. I have something to say that I can't on here.
