How low is safe to go when running out a tank of gas to test your mpg? Should i fill a gas can and put it in the back just in case or...? I know some cars (especially 22 year old cars) it's not a good idea to run the gas tanks dry. What's the actual tank capacity?
How low to run out my gas when testing mpg?
Originally posted by festiva351w View Postwhy do u wanna run it out of gas to check mileage? i've never heard of such a thing, running it out is not a good idea, if theres any dirt or water in the tank it's more likely to get into ur lines and filter, if u run it dry90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View Post+1. Instead, be really careful to fill it completely when you fill it up the first time, drive it for about 8 gallons or so, then carefully fill it again.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
You don't have to run it super-low. If you pay at the pump you can do what I do. When you fill up there's typically a fuel amount on the reciept so just make a note of the mileage on the receipt. Drive the car until the fuel gets as low as you want to run it without running out. Go fill up again, then make a note of the mileage on that receipt. Then just use the gallons used vs. miles driven from the 2 receipts to figure out your mileage. Using this method you can check it at whatever level you want.
Originally posted by Zanzer View PostYou don't have to run it super-low. If you pay at the pump you can do what I do. When you fill up there's typically a fuel amount on the reciept so just make a note of the mileage on the receipt. Drive the car until the fuel gets as low as you want to run it without running out. Go fill up again, then make a note of the mileage on that receipt. Then just use the gallons used vs. miles driven from the 2 receipts to figure out your mileage. Using this method you can check it at whatever level you want.Festiva: Because even my dog can build a Honda.
I've read that the fuel keeps the fuel pump cool which is the reason that running out of gas is a BAD idea. I've heard of poeple that had to replace the fuel pump after they ran out of gas. I would just run it low as stated above.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I typically fill mine to just before gas starts running down the side of the car, and run mine down til about 1/4 tank. I don't compute my MPGs every time, but I pretty much always write down the mileage. Usually figure MPGs once a month, or so. Pretty much average between 43 and 45. Not bad for a carby, eh?
And +whatever number we are up to on not running it all the way out. Just asking for trouble, IMHO.
1989 L - 247K miles Slick
Yeah i don't actually want to run it out...that's what i was asking. I was just thinking along the lines of filling up with X amount of gallons and driving that total number out and just multiplying the miles by the gallons to see what the mpg was. How else can you know if you've used 8 gallons completely or whatever?
Originally posted by Evil D View PostI was just thinking along the lines of filling up with X amount of gallons and driving that total number out and just multiplying the miles by the gallons to see what the mpg was.'90 LX
LOLWe didn't want to say anything...we were just hoping you caught these:
Originally posted by Zanzer View PostYou don't have to run it super-low. If you pay at the pump you can do what I do. When you fill up there's typically a fuel amount on the reciept so just make a note of the mileage on the receipt. Drive the car until the fuel gets as low as you want to run it without running out. Go fill up again, then make a note of the mileage on that receipt. Then just use the gallons used vs. miles driven from the 2 receipts to figure out your mileage. Using this method you can check it at whatever level you want.Originally posted by JPT View PostThat's what I do. The more gas you use, the more accurate your MPG calculations will be, but never run it empty.
Hahaha...I feel your pain man! My 79 Bronco with the 429 got 7mpg. Checking the mileage was the LAST thing I wanted to do. Every time I passed a gas station it wanted to pull in and I was like "you just ate!!!"
The first week I drove my Festiva, I thought the fuel gauge was broken :toothy3:
