I'd just done some repair work on my Blue Festiva, and decided to take it for a spin.
Everything went Ok until I pulled into a deserted cul-de-sac to turn around. I spun the wheel around, and then it happened.
I heard a dull 'clunk' from the passenger side, and then the whole car lurched and skidded in the opposite direction I was turning.
Some genious didn't bother to tighten the nut that holds the sway bar/control arm joint in place. The sharp turn I took was enough to wrench it out of its socket and scare the sh!t out of me.
It also seriously screwed up the steering alignment and yanked out the passenger side CV joint.
It took 5 people 3 hours to pick the car up and pull it onto a trailer - a very difficult job when you have 2 wheels that want to go in opposite directions.
I was VERY lucky this didn't happen on the main road or at high speeds. I could have been killed.
Now I have to put the damn steering back together and get the stupid thing re-aligned, which is going to cost me more $$$ that I don't have!!! Even worse, it made me late for a date!!!!!!!!!!!!!!!!!!
Regards,
Tim
Regards,
Tim
