The festy I'm currently working on is a 92' with 90K on the original B3. The motor runs strong so the first things I'm going to do is just work on the suspension and make it handle better. If it ain't broke don't fix it right?
In the mean time I would like to source a BP to install whenever the B3 does decide to give up the ghost. And if it takes a while I can just beef up the BP while it sits in the garage.
My questions are these:
Will I be able to use the stock transmission or will I have to go with a G25MR? I guess those are out of the 323 GTs and XR2 Capri's right? Any other cars they might be in that I could source one from? What about the Escort GT or Protege LX tranny?
Second, I've seen plenty of guys one here bolting turbos and rear turbo setups onto their BP/B6 engines. Have any of you all done anything internally to the engines or is it all stock? Can the BP handle 10lbs of boost on a regular basis on stock internals? What about the injectors? More air needs more fuel right? What are you all doing to compensate for this?
Lastly, these rear-turbo setups I've been following, what are the advantages to that other than being able to keep your A/C? I would like to keep (well, install rather) A/C on my car (Louisiana is just too hot to be without it) and it seems like the perfect solution. But what about turbo-lag? I suppose if it is on a stock engine with stock compression that wouldn't be an issue and if that's the case does the turbo come on as one big lump of torque halfway through the curve or what? Are there any disadvantages to having the turbo so far away from the engine (e.g. length of the pipe effecting pressure, etc..)
I apologize if these questions seem elementary but I've done quite a bit of searching before I asked. Plus, you guys are experts on this! Thanks!
