rear wiper question
  • rear wiper question
    when wiper is off should it stay up or down?
    Up, unless you modify it like some have with an escort motor. If you hit the switch just right, it will sometimes stay down, but it is supposed to park straight up and down.
    Michael
    Have owned 9 so far
      I can tell you what happens when the wiper arm is removed and installed in the down position. When you turn the switch on it will clean the hatch for you, it just won't reach the lic plate.:p I had one I purchased that the PO had a guy replace the motor and I guess he never tried it after putting it all back together. So I turned it on when I got the car home and was like DANG.
      91 Festiva GL "Scrat"
      82 Honda Goldwing GL1100i
      85 BMW 535is "Brunhild"
