I found a b3 carb motor. Will my fuel ejection work on a carb motor?
I have a 91 auto I think the motor im looking at is out of a older car.
Yes, you will need to change the intake and block off the fuel pump hole in the head.The disty will also need to be swapped out. Your fuelly engine should have the cover and everything you need. Then you can give me the carb parts off the old engine.
ok! it a deal, If i get the carb motor all the stuff i take off is yours. Thanks for the help.
my number is 757.705.3592 if you have anymore questions or need advice. You can either text or call. I may even be able to help, depends on when you are doing it. It's about a 4.5 hr ride, but if you get in a real bind I can make it.
Thanks, I did a swap once and it was not that bad. I got the motor from Dean and he helped me get it running, Man, I miss that guy. But I will take the # and call if I need help. Ill let you know about the carb parts as soon as I can.
That is why I dedicated this last Festiva in Dean's honor. He was a very kind and helpful man. You can see it in the FOTM section, and I still have a lot of little things to do to it. Maybe you can see it in person in July in Lincolnton at 4TH Stiva.
