ok i had to replace my stock transmission and im faced with a choice between a four speed tranny or a five what would be better performance wise?
transmission choices
depends what you mean by performance. (mpg's or 1/4 mile time)
check out this thread:
-Aspire brake swap COMPLETE!
the only diffrence between a 4 and a 5 speed is the 5th gear... the best stock "performance" trans is the aspire one cause it has a higher final drive giving you better acceleration...
Mike, AKA the sasquatch
Originally posted by NeptuneZeek View Postya i want performance that if i pull up next to some one who wants to race i can blow him out if that describes the performance i want lolLast edited by ejp2fast; 06-12-2010, 10:55 PM.
There may be a slight performance advantage to the 4 speed due to the lower final drive ratio, but I would go with the 5 speed for the extra overdrive ratio. Especially if you do any highway driving.Brian
this is a moment where i wish i had two festivas lol but i recently got a nissan 300zx with the talking computer in it its just that i cant work on it being in florida but will that affect its max speed because the speedometer in the mazda said 145. will the four speed render some top speed?Parker
Originally posted by NeptuneZeek View Postwill the four speed render some top speed?
so that means im gona need to be carefull i guess. in the future what would be the best transmission swap to get a bit of both worlds when it comes to mpg and acceleration? and i want to lower it down a few inches then get better suspension. i dont want to sound needy but i dont want to make mistakes on upgrading this car because im learning and asking questions from more experienced festiva drivers would do me some goodParker
g series would be the best as its beefier and all the torque provided by the engine will be put down in a safer manner... the f series 4 spd you'd need to baby it as its weaker and hard lauches would reduce the life drastically...
thats why we're all here - to learn!
escort gt 91-96
merc tracer lt-s 91-96
see that link above..
and no, a 6spd is not available.. unless custom..?Last edited by ejp2fast; 06-12-2010, 11:31 PM.
post #2 thread is what i meant
