What's this?
  • What's this?
    What is this?
    My Musica! Click me!
    Check this out:
    okeey. Installation Time: 30 minutes - 1 hour Difficulty Level: 2/10 Tools needed: -Ratchet set -12mm die (deep socket) -12mm die (regular socket) -Scissors or X-acto knife -Jack -Jackstands Hardware Needed: -8 x 1.25 x 40mm Stainless Steel Bolts - MAKE SURE THEYRE FULLY THREADED (these...
    Similar? It's the same name brand and look.
    My Fleet:
      So, it makes for a tight rear?
        This one looks like it goes on the underside.
        -Donny
        -1992 Festiva GL
        B6D/E-series.
        -1991 GL
        BP/Broken E-Series. Working on G transmission.
        -2011 Mazdaspeed3
